01.12.2013, 06:57 PM
That's a pretty equal match.
I'd take a neu 1515 over the hobby wing any day.
Power wise the 1515 probably has a slight edge, but very slight.
The neu will definitely be more efficient, giving you slightly longer runtimes, running a little cooler and getting away with a wider range of gearing.
An additional advantage is being able to send it to neu for repairs should a failure ever occur, with the hobby wing you're just out a motor.
If you're looking for more power a neu 1521 or a castle/neu 1717 are the next step up.
