Thread: Tires/Wheels
Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.24.2013, 05:58 PM
Originally Posted by Emaxx Derek View Post
How is it done "right" then? I've tried the RPM carriers, and aluminum ones (I think GPS...those are installed now...at least the balls aren't coming out of the carrier any longer). It is easy to adjust and that's great but, having to fight between the servo and the pillow ball isn't that efficient. If I could change the entire system I would in a heart beat.
I will try to thread lock...thank you..that's a great idea.
It sounds like you are over torquing the pillow ball caps that keep it seated in the carrier. Things wear in a pillow ball setup and require occasional re-torquing. But when done right its smooth as ice with zero binding.
I use hybrid Spherical Rod bearings on my TransAm's suspension pieces. The handling change from losing all the slop and getting that freedom of movement is incredible, the car is so much more alive. Just have to live with a little more road noise.
http://www.umiperformance.com/catalo...age=roto_joint
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
