02.12.2013, 09:23 AM
Are the actually LIons, what are the voltages? Did the saw sound like it was reciprocating as fast as normal? Over triple the capacity from the same chemistry in the same size can sounds suspicious to me, NiCads only doubled in their whole lifetime and NiMh are approaching their death and still haven't doubled, despite subC cans growing.
Do you have a spec sheet for them?
In boat racing were we have maximum battery weights we are now seeing some cells that offer more energy density but sacrificing power density, 6200mah cells the same weight as most 5000s but 14c instead of 30c+, while that is less than 25% increase in capacity for a 50% reduction in current capability, could it be possible that they have taken that same ratio to the extreme doing it 5 times would net near 3400mAh, say the original LIons were 30C reducing the C rate 50% 5 times leaves a <1C cell, using it at anything over 3A could be taxing it severely and reducing its capacity, did they warm up in use?
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
