Robl45
02.28.2013, 08:01 AM
The Losi mount is 43mm inside diameter. I mounted the Losi conversion tray up front on my truck, but I did not use the stock mounting points of the tray. In my opinion handling benefits from the battery being up front. On power steering is improved tremendously and the truck will still wheely easily even on 4s.
Thanks, I wasn't clear about the battery, I was going to mount it up front in front of the transmission where the servos would be like many people do, but since it already has holes and mounts in the back where the fueltank was, I figured I might mount it up front where the radio box is since the mount should be the same. But that puts it further up front and also up a bit so didn't know if that would be too forward.
