CerberusVI
CerberusVI's Avatar
04.04.2013, 10:18 AM
Xtm did make a center diff upgrade but with a goofy 63t spur gear and planetary gears inside instead of spider gears. I have one, but the spur has been stripped and finding one is close to impossible.
I've been doing a lot of research and cross referencing and I think I'll be able to use spider Diffs out of the newer xtm xt2e. I have only found one report of the xt2e center diff and motor mount working on the xlb and all that was said was it works with a little modification....
