Dragonfueled
Nore more bump boxes and after run oil
05.01.2013, 06:47 PM
It's firmware related. If I update to 1.39 firmware on my old monsters it does the exact same thing. Once I go back to 1.32 it's fixed. You guys don't have this problem with 1.39 firmware in your monsters? If you give it throttle and the yellow light stays lit with the green one for two seconds you have the same issue.
Brushless ..... I put that s... In everything.
