Overdriven
Destroyer of Tires
Overdriven's Avatar
05.03.2013, 08:23 AM
Originally Posted by Dragonfueled View Post
Did some more testing. When I punch the throttle the green and yellow led light up till the rpms come up then the yellow goes out and I get full power. If I maintain some rpm and punch it I no longer get the yellow light and I get full power rite away, let the rpms drop to much and when you nail it the yellow light comes on with the green one again till the rpms come up again. Any ideas?
That sounds like its staying in its "startup" algorithm too long. Firmware might be to blame, maybe try reinstalling the firmware if you can. The other possibility is the firmware is fine and the esc is staying in "startup" algorithm too long because it doesn't detect the emf feedback from the motor the way it should. If that's the case it's hardware related and needs to go back to Castle.
