Thread: Charging 7S
08.27.2013, 07:08 AM
If that wire is not needed for series charging then they haven't really fudged it up then. They've made it so the correct wire gets left out. Each tap can still be used on a stand alone balancer if needed.
What I am worried about is which tap from the battery pack goes first
It's not the correct wire getting left out though, they are tapping into both grounds and thats no good. It should only be one ground going into the charger. My description above explains it.
A simple use of the voltmeter will show polarity and which lead goes where.
