WheelMan
Do Epic Sh!t
WheelMan's Avatar
09.06.2013, 08:51 AM
well no feelings were meant to be hurt, by any means! My knowledge on what a Typhoon is, was very limited, as I've never paid much attention to GMs, so I guess I chose poorly on my wording, haha! Now that I know a little more though, it seems your analogy is spot on!
You are very correct on the window. Before I started, I was expecting that I was gonna have to frame the sides in for a door, but whoever built my garage, definitely did me a favor. The window not only had a header (as expected), but it was also framed in clear down to the floor, perfect for a door! So all I had to do was remove the window, cut the section of wall out from underneath of it, and then pop the door in! Of course it took more work than that, as I had to pull almost all of the siding off on the outside, lol, but you get the point.
Thanks! I love my RR! Currently collecting all the parts I need to swap the front forks out for an 07 inverted setup
-Travis
Adults are just kids, with money.
Common sense, is not so common.
