Jammin X1 Crt conversion
CerberusVI
CerberusVI's Avatar
Jammin X1 Crt conversion - 09.24.2013, 08:25 PM
So i picked up a Jammin X1 CRT for a really good deal, but i dont run nitro anymore and everything i own is now brushless. after factoring in the cost of a nitro motor, pipe, clutch, air filter, nitro, after run oil, possibly a bump box, i would much rather convert it cost wise..even though i kinda want to get back into nitro lol.
SO my question is, is there a reasonably priced center diff mount i could pick up? The RCM one for the X1 crt is designed for the "ferris wheel" sized 62t spur, I already have a 46t to convert it to a smaller sized spur. I measured the mount and it has a 22mm screw spacing. Will the Hyper 9 center diff mount fit? I've seen some of the Ofna mounts for the LX1 and LX2e but havent found any specs to help me out.
If anyone has some ofna brushless conversions measuring the distance between the two bottom screws (center to center) would probably point me in the right direction also
