Thomas Porfert
Thomas Porfert's Avatar
01.24.2014, 01:01 PM
Originally Posted by whitrzac View Post
The question with the brushed sidewinders is, are all of the brushless parts there and just needs a wire soldered on?
I would really like to be able to use the et-3s for 4s+...
Doesn't the traxxas monster have a few versions too? With cap-pack/without?
I think the axial brushed is a modified board much closer to the Holmes brxl's
I know for sure that the Holmes is completely different circuit boards that is laid out for brushed; it only have 4 FETs. I would assume the axial is the same but I've never seen one before.
The 3s limit on the ET-3s was put there at the request of Traxxas; because it's installed RTR in the dragster and if you run it on 4s the motor becomes unhappy (IE cooked).
And you are technically correct (the best kind of correct), the XO-1 monster is a modified Monster and does include the cap pack. I shall correct this egregious error in my previous post.
Thomas Porfert
Tech Support
