whitrzac
Can't catch this...
whitrzac's Avatar
03.19.2014, 04:16 PM
Originally Posted by Thomas Porfert View Post
Now you know I can't speak about any new products that may or may not be in development. But it would make sense for us to redevelop the Mamba Max Pro and pack in some of the newer bells and whistles. IE data logging, waterproof, bigger BEC, sensor port moved to the top, removable receiver wire. We have been listening to customer suggestions and taking notes over the last few years. The above list seems to come up the most consistently when people are looking for upgraded features for a Mamba Max Pro and Mamba Monster..
Thomas Porfert
Tech Support
Has it been 5 years? I remember buying mine at Ihobby when they were first announced
It MUST be durable. My MMPs have been through hell and back and they still work. I have one that's been plugged in backwards twice(that was a bad day) and one that's had the BEC/parts blown OFF the board, they still work.
I stopped using tekins, novaks, etc because they had the bad habit of dying at the worst possible times, even though they are 'faster' on the track.
Ability to run 70*+ static timing motors. Tamiya TCS went to 21.5 this year. The fastest motor is revtech with ~78* of static timing.
Wants:
Removable fan would be nice. Make 2 versions? one with heatsink/fan, one with smaller heatsink/no fan(same internals). Even if they are the same price...
If your adding dataloging make sure it can do current, and add an extra port for a temp/RPM/etc sensor/2.
Solder posts or a way to change the wires
'link' jack on the esc.
Keep whatever sensor jack your using. It's the only one I've seen that the cable doesn't back out on.
External "fan" jack with adjustable output. So I can run fans at 8-10v when running 6s.
Custom startup tones?
