04.08.2014, 04:24 AM
Thanks for the reply! I will try changing the timing and report back.
I'm running a Mamba Monster Max with the internal BEC set at 7V with a 3300mah electrolytic cap and two 100mah tantalum caps to help combat brown-out issues.
The reason why I don't believe it is glitching is because I still have full steering response when this happens and the system ran fine for multiple full-pack runs prior to this issue happening.
