Originally Posted by A RC Dude
I have one, something is wrong with the start power and I just shipped it in. It ran perfectly at speed (above 3mph or so) but below that there was barley enough power to get the truck moving, much less spin the tires as it did from 3-20mph easily. It did this with two motors.
And I dislike the removable RX wire...I had to bend the pins around and use a zip tie to hold the wire and get it to make a good connection during a run and not come unplugged...
I'm sure the first problem was an error in manufacturing on mine, as for the second, i'd rather have a female rx plug than the three pins that fit too loosely
Fix those two things and it'll be golden
Thanks for the feedback !!
Hadn't seen any issue with the removable RX wire yet -- that's interesting that you are seeing it come loose. I'll have the engineering team here look at that and see if there's anything we can do to fix the issue on this side.
The start power issue is probably just that -- start power is set too low for your particular motor. Have you tried bumping it up?
Thanks!
Patrick
