nativepaul
nativepaul's Avatar
07.05.2014, 06:45 PM
Brian, you are a god amongst men. I thought you may know what is what but I didn't dream that you would have done it before and be able to give me that much detail. Thank you.
I hadn't thought to double check the programmed voltage, I will make sure to do so.
My phone is a Galaxy S3, so your info on the 200ohm resistor is invaluable, I never would have guessed it needed that.
I have a spare 16v 470uh and 25v 1000uh ultra low ESR capacitor left over from ESC mods I can use, should they be fitted in the same way as they are on an ESC, bridging the positive and negative wires? That makes sense to me as they are doing the same job, but for some reason I feel that they should be bridging a gap in the positive.
As you can tell I know nothing, so thanks again for your help, I would be lost without you.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
