08.16.2014, 08:40 PM
Originally Posted by Big House View Post
I have tried my hand at balancing but I don't have a balancing jig. I was using a spare axle and knuckle to hold the wheel in place but it is not smooth enough to let the wheel freely spin and come to a rest on the heavy side. Still working on that. What do you use as weight?
I use adhesive whhel weights that I cut up into smaller pieces. I then cover the weight with hot glue. Make sure the weight will clear the knuckle... I modded a cheap airplane prop balancer. I will set it up and take a pic.
Be careful with conversing with lincpimp. He very easily develops man crushes and becomes infatuated. I'm still seeing a therapist over some of the disturbing pictures he sent me of himself.
Those pics were of RcHippie, and you asked for them. And if you want to call that Pilipino Ladyboy your "Therapist" that is your business. However don't expect the rest of us to believe you.
