Lizard
Lizard's Avatar
09.08.2014, 06:53 AM
Thanks :) Yeah, I hope that thing will rip seriously.
Now it's nearing finished state.
Chassis tray and chassis brace are now on the car. Then made another brace using Savage hinge-pin braces from the wingmount to the aluminum profile in the rear. Chassis seems very stiff now. Batteries are strapped to the chassis with two big straps that go between the chassis-tray and the chassis-plate.
Wired up the ESCs and plastidipped everything. Wiring is not really clean, will do this later. As a switch I used an 8-pin socket/plug, this switches both ESCs, the BEC and the 24V on simultaneously. For testing purposes I made two extra plugs that allow to switch on the ESCs seperately.
The BEC is a 7A 5.5V Hobbyking BEC, Servo is Savox SA-1283SG with 300Ncm at 6V. Without extra capacitor, there are glitches when moving the servo fast, with capacitor it seems to be okay.
Wires are all 0,5qmm silicone wires and the plus and minus rails on the Traxxas TQI receiver habe been re-inforced with copper and solder to make sure the servo gets enough power.
As you can see, the ESCs are now right next to the motors, this way they can be cooled by the same 80mm 24V fans that cool the motors.
RTR Weight as on the picture with 225g PMT 1/5 scale GT tires is quite exactly 8kg or 17.6lbs.
Theoretical topspeed is 78mph now with 3.7V per cell, 4.72 inch tires, 46/20 gears and 2.888 CEN diffs.
The Mamba Monster startup beep sequence is "polyphonic" now, sounds cool :)
Did a quick testrun in my home on tiles. It cogged a little. Gave it more throttle, now I have some black rubber marks on my tiles. Feels really powerful already. Need to test it outside.
