wade7575
09.18.2014, 10:33 PM
I knew that running 5S will help my stuff run cooler then on 4S and thanks for the advice,I know a fair bit about RC and although I have never built an 1/8th scale before I know that it will not pose any problems for me to build and I'am thinking of running 5S if I can find packs cheap enough and are of good guality.
Keep in mind that more voltage equals less amp draw when both setups experience the same load.
So if you have 2 identical trucks setup to run the same the speed, the higher voltage truck will have less amp draw than the lower voltage setup.
Less amp draw generally equals cooler components. Especially the speed control, which will likely be the same for both setups.
