First version of the extended rear shaft, simply cut and welded, didnīt hold up to my abuse
This is the second version. Cut, inserted in a handmade steel tube with six 4mm holes in it, welded in the six holes, then finished in a lathe. All done by a very skilled friend of mine called "Karlsson"
, this version has taken som serious abuse and still holds up!
Basher approved:
Some plumbing was done, oops pic taken after the first testdrive....:
The aluminum bulkhead mounts:
The custom skidplate, also mounted after the first testdrive, was going to not use a skid, but bent the rear centershaft so decided to moke one up:
How the servo sits and are connected to the steering rack:
