Mr E-Maxx
Mr E-Maxx's Avatar
10.28.2014, 03:36 PM
Hello,
Thanks for you the Tipp. I had the same idea to turning in the pillow in but it wasn't enough. When I used 17mm hex like the stock one I made some 2mm spacers between the Axel and the Carriers. With this Set-Up the Driveshaft was long enough. Are the Hyper7.5 Outdrives longer than the UE? I need only 2mm. With the stock Axel Carriers everything fits, but if I use the RPM I will need 2mm more. I can’t use the stock ones, because I broke them to much and I destroyed the big bearing so often. I hope that I can take a picture tomorrow of a temporary build.
