molak
11.14.2014, 09:52 AM
Originally Posted by Dr_T View Post
Not sure if and how max Current can be controlled with that ESC, but technically you don't need Current sensor to do so, as the Current follows from the Voltage drop across the motor anyway. At least that's how it seems Castle implemented their Current/Torque control: http://www.rc-monster.com/forum/show...56&postcount=2.
By using a shunt you measure the drop across a know resistor... You donīt need any test and is motor independent.
Even if the ESC has no user modifiable current limit, The esc may have a maximum current limit to protect itself.
