Lizard
Lizard's Avatar
11.23.2014, 07:24 AM
Not sure about the ESC yet, need to test the sensors first and then try if it runs. Weather is nice and I have finally received my new transmitter, will probably find out later today...
Diameter of the base is 14mm.
Regarding the low-kv motor and the XO-1: Will only run 6s on it with that motor. It's not that bad on the XO-1 because it has 2.85 diff ratio and 4.29 inch tires. I went with a Revo 3.3 Slipper that can run 34t to 42t spurs, that gives me enough gearing options.
