othello
HV basher
01.09.2015, 10:31 AM
If you read the product page of the Castle Talon HV 120 ESC you will notice this at the end of the page: "*** Remove BEC Power wire from receiver before connecting to Castle Link"
Not sure how to interpret this the right way:
- first i thought ... oh castle might see an issue related to the XL2 sending power through the battery wires when it is connected to castle link and this could lead to esc failures.
- on the other hand: in order to connect the ESC to castle link you would have to unplug the "cable" anyway from the receiver and plug it to castle link (maybe it works differently with the talon HV esc, since having to unplug the esc from the receiver each time you want to retrieve data from the esc is not very practical. A design change would make sense ... as for example a second wire only for retrieving data which you could route outside of the receiver box for quick connecting ... idealy a bluetooth/wifi connection to a smart phone would be the next step).
- or: if you remove the "red" wire from the plug (leading to the receiver) the esc won't power up when connected to castle link (at least the xl2 needs the red wire in order to be powered from castle link ... which is also a source of error if you don't use the internal BEC of the esc (as i do with the xl2)).
So ... i got a little confused.
Regarding the porsche: geared for 95km/h. Not wheighed yet. i suppose something between 10 to 11Kg. If you are interested here is the build thread (although in german). Wanted already to start a new thread here at rcmonster.
