Thread: Arct1ks project
01.10.2015, 06:37 PM
The steering stops...
So one of the issues encountered was that at full lock the wheels would rub on the front A arms. Even before the car reached NJ the arms are looking pretty scratched up and the powder coat has chipped off :( In addition one of the NJ inspection items is that the wheels shouldnt hit anything as they go through the full range of movement.
I took the idea from another owner to create steering stops which would attach to the front hubs and reduce travel enough that the wheel won't contact the arm.
I started with some cardboard cutouts to get the rough shape, progressed to a CAD drawing (eMachineshop is great) before a final mock up on the car.
Next it was over to a friend Mike @ RC-Monster.com for some machineing - 1/4" 6061 should do the job. I asked Mike to leave the hole at 3mm so that they would act as pilot holes when I came to drill and tap the hubs. Mike was able to turn them around in a couple of days :)!
All that was left was to brave the -6C 20F weather today to drill and tap the hubs and mount them up. I used 1/4" - 20 bolts to hold them in place and some 1" X 1 1/2' rubber bumpers top and bottom to act as the stops.
This will enable the bumper to work over 2.5" of travel which should be more than enough.
Thanks again Mike!
