Thread: EMaxx chassis
ta_man
02.04.2015, 12:29 PM
Square inside corners are simply not possible to machine - I will look at tightening the radius of the inside corners with this comment in mind, though. The trays will be plenty big enough to handle the typical hard case Lipo without needing to stuff it into the corner tightly.
You can get most of the effect of square inside corners by moving the cutter a little into the corner on the lengthwise traverse, and backing it out again before the traverse across the width.
Is this new chassis going to have the old E-Maxx layout with the trans in the center or the new E-Maxx layout with the trans up front?
