maxxdude1234
maxxdude1234's Avatar
04.08.2006, 04:26 PM
Originally Posted by Serum
just do a testrun, it saves you a few days of calculating.
Also, once you've got a rough idea of the runtime you get with your system, if you change to different capacity batteries you should be able to get a fairly accurate idea of runtimes. ie, If you got 15 minutes with 3000mah packs, you should get 30 minutes with 6000mah packs.
