Dragonfueled
Nore more bump boxes and after run oil
08.06.2015, 01:20 AM
Hi just got to play with my monster x and have a few questions.
I did the kv test on my 2650 and it came up as 3250. Wouldn't that make the motor a 1600 kv motor? That was with no pinion just the motor spinning. It's a new castle 2650.
Does it matter what I set torque control to on the castle link when I assign the aux wire to torque control?
Or does setting the aux wire ser to torque control overide Whatever I have it set on the castle link.
On the aux wire it seems to work from neutral to full negative travel. Does positive travel do anything? Like is neutral basically torque control disabled and full negative travel full torque control?
Brushless ..... I put that s... In everything.
