Lizard
Lizard's Avatar
08.06.2015, 04:08 AM
This is what the help text in the CastleLink software says:
Torque Control Adjustment
The controller's torque limit is controlled by the AUX wire signal. The torque control is scaled from 0.1 at 1.1ms signal received on the AUX wire to 5.0 at 1.9ms. Torque control is disabled when the input exceeds 1.9ms. If the AUX wire becomes disconnected, the controller will use the torque limit set in Castle Link.
It depends on your radio make and model what the 3rd channel does. And of course how it is configured. The range for "servo signals" is usually from around 1.0ms to 2.0ms (depends on make and model, there is no real standard). E.g. the throttle channel gives 1.0ms at full brake, 1.5ms at neutral and 2.0ms at full throttle.
This box can read out the signal from the receiver channels and show the ms values, makes it a lot easier, sometimes it's hard to tell from the manual what the extra channels do exactly.
http://www.hobbyking.com/hobbyking/s...ogram_Box.html
Here is the log already on the Monster X:
