Wiring Cap pack parallel to ESC wires?
ruudxd
Wiring Cap pack parallel to ESC wires? - 08.21.2015, 06:35 PM
Hello,
Seeing the discussion about ripple voltage, and seeing that it is bad for your ESC, I want to re-install my cap pack to my Mamba Monster 1.
The previeus owner installed it in the spot where you can see the heat shrink, where the BEC wires go to also:
But I removed it because it didn't fit because I use a fairly big battery ( Gens Ace 5000mah 45C 6S ), it would stand upwards, and I had to force the body one the posts.
Now here comes the question, is it possible to wire the cap pack parallel to the ESC wires, with some smaller wires so I can place it somewhere else in the car?
Like seen here ( excuse the amateuristic "paint job " but, you get the idea I hope )
I am thinking about taking the BEC wires back more to the ESC side, and then put some wires parallel to the cap pack ( as short as possible ), is that possible, or does that completly eleminates the use of the cap pack?
And if it is possible, what gauge wire do you guys recommend?
Sorry if these are some stupid questions!
Thanks a lot for all the help, it really means a lot to me!
Ruud
