Pdelcast
Pdelcast's Avatar
08.26.2015, 10:47 AM
Parallel is correct.
However, you want to keep the length of the wires to a MINIMUM, as long wires negate the effect of the extra capacitance.
Also, use heavy wires -- maximum currents sourced and sunk by the capacitors can be very high (>100A for short bursts) -- so they need heavy wire to reduce inductance.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
