Thread
Losi LST tips and tricks ( 3mm, 4mm screw mods, how to shim LST diffs etc ) Pic heavy
4
ruudxd
09.11.2015, 04:42 AM
FOC Conversion:
TiNi Gear is installed on the top shaft to gain additional topend, I've just started doing it to all FOC tranny's. You must loctite the screw that holds the pinion gear well...Take this opportunity to shim your topshaft for no slop.*
Slight dremel work done to case halves to make the gear fit.
I like to stick this top plugs in while the case is apart, they are difficult but you can do it!!
ruudxd
Find all posts by ruudxd
