Answer comes from
http://www.aveox.com/technical/dc.html
Calculating Motor Performance
Use these handy equations to calculate steady state motor performance. A spread sheet will help in visually graphing motor parameters. If the Torque constant is not supplied by the motor manufacturer, you can measure the motors no-load RPM/Volt and use the following equations to calculate the torque constant.
Torque constant: Kt=Kb x 1.345
Current draw of motor: I = [V-(Kb x kRPM)]/Rm
Torque output of motor: J = (Kt x I) - (Kt x Inl)
RPM of motor: kRPM = (V - RmI) / Kb
Power output of motor: Po = (J x RPM)/1345
Power input: Pi = V x I
Motor efficiency: Eff = (Po/Pi) x 100
Current at peak motor efficiency: Ie max = Sqrt [(V x Inl)/Rm]
Symbol Definitions:
Eff = Efficiency
I = Current
Iemax=Most efficient current
Inl = No load current
J = Torque (oz-in/A)
Kb = Voltage constant (Volt/1000 RPM)
Kt = Torque constant (oz-In/A)
Pi = Power input (Watts)
Po = Mechanical power output (Watts)
Rm = Terminal resistance
RPM = Revolutions/minute
V = Voltage
Based on this motors with the same Kv numbers have the same Kt numbers, but RPM and Amps will be different. Meaning that power output of both motors won't be the same.
Artur
P.S. Apply the same math for this
http://www.rc-monster.com/forum/showthread.php?t=2775 as well.
