Originally Posted by re-hooked
V-Revo gotcha...so want need a BV-Revo (modified chassis for Big Block Victory Nitro engine series chassis). If there is a way to allow a BB to BE mounted dead center on a chassis I think that would be sweet?
Whatchathinkofdat?
Are you suggesting a nitro big block revo with a center diff? A center-mounted motor would raise the motor an inch +/- from the stock location(higher cg) unless the diff was offset, so probably not as effective as it sounds.
