re-hooked
11.13.2015, 03:35 PM
Are you suggesting a nitro big block Revo with a center diff? A center-mounted motor would raise the motor an inch +/- from the stock location(higher cg) unless the diff was offset, so probably not as effective as it sounds.
Yes I was....I was thinking about two separate "possible" designs.
1. Center mounted BB engine with RAISED or elevated transmission case. Transmission case mounted in the same location. Here my thought was that BB would be able to engage the Spur gear on the right hand side rather than the left like it does today. Raising the transmission would allow the engine to remain low. The center drive shafts would need to be longer but there are plenty to choose from.
Or
2. Center mounted BB engine with a double-decker chassis. Completely redesigned chassis - I guess more like a truggy chassis (maybe I should just buy a truggy) LOL....
But I seem to recall toying with the idea of flipping the chassis over and trying to mount all the gear back onto it but with the engine centered. Didn't get very far with this idea but it's still with me.
