Originally Posted by re-hooked
Yes I was....I was thinking about two separate "possible" designs.
1. Center mounted BB engine with RAISED or elevated transmission case. Transmission case mounted in the same location. Here my thought was that BB would be engage the Spur gear on the right hand side rather than the left like it does today. Raising the transmission would allow the engine to remain low. The center drive shafts would need to be longer but there are plenty to choose from.
Or
2. Center mounted BB engine with a double-decker chassis. Completely redesigned chassis - I guess more like a truggy chassis (maybe I should just buy a truggy) LOL....
But I seem to recall toying with the idea of flipping the chassis over and trying to mount all the gear back onto it but with the engine centered. Didn't get very far...with this idea but it's still with me.
Option 1 seems like the rear-center shaft would have to pass through the engine - don't see it happening. Any option that has a centered motor will have this challenge(which is why Losi offset their rear diff on their 8 lineup - to get the motor closer to the center, though this creates other problems(extreme angle on front-center shaft leading to high wear and heat).
Now, a truggy chassis that uses a Revo suspension setup would be nifty.
