re-hooked
11.13.2015, 07:59 PM
Option 1 seems like the rear-center shaft would have to pass through the engine - don't see it happening. Any option that has a centered motor will have this challenge(which is why Losi offset their rear diff on their 8 lineup - to get the motor closer to the center, though this creates other problems(extreme angle on front-center shaft leading to high wear and heat).
Now, a truggy chassis that uses a Revo suspension setup would be nifty.
Hey.....I really like the thought of this. SO if you did that would you do something better for the diffs\bulkheads? The Truggy chassis with Revo suspension would open provide new options for larger spur gears right?
Fabricating something that allows the front/rear bulk heads and rockers to connect to is all that is needed. The same design could be used on the front and rear.
I think it's a good idea...
