GriffinRU
04.09.2006, 11:33 AM
Originally Posted by Re~Mix
Okay what exactly am I suppose to buy and how to use it? Something that I can just dip a few mm of the wires in and be done with? Thanks a lot, I know i'm stupid for cutting the wires, but hopefully I can redeem myself.
You need Aspirin tablets from the pharmacy. Then take one tablet out. Put it on a metal tray/surface. Put one wire from the bundle on the tablet and heat it with the solder iron [keep area well ventilated, the smoke is very nasty]. Once the tablet starts melting, move the wire around on the surface of the tablet until all the coating is gone. After the coating is removed, tinning with solder won't be a problem. Then proceed with the rest of the wires in the bundle. When the last will be done, clean the wires with water, twist them together and apply solder. One motor phase done.
Artur
P.S. In theory (I have never tried that) you can melt couple tablets on the hotplate and then submerge wires and use metal brush... But man smoke will kill you :(
Just a thought - what about sand-blast?
