Pdelcast
Pdelcast's Avatar
04.07.2016, 03:15 PM
Originally Posted by Dr_T View Post
As long as "no-load kv" x applied Voltage does not exceed the motor's max RPM, revving unloaded for a bit shouldn't cause any problems, right?
That's correct.
And you can always run the Kv test with a lower voltage too... it will still work correctly.
So, if the application is for 4S, you can run the Kv test with 2S if you are worried about overspeeding the rotor.
A lot of cheapy motors out there are skimping on rotor materials -- so the concern is not unjustified.
Patrick
Patrick del Castillo
President, Principle Engineer
