Thread: In Stock
jcflyer
04.12.2016, 11:09 AM
It's the same diameter and only .3mm longer than the castle 2028 and hence It should fit fine.
It only used a 5mm shaft though so you will need a pinion adapter most likely.
I am not sure what you mean by 5mm, the motor I am looking at uses an 8mm shaft. Are we talking about the same thing?
