Dr_T
Dr_T's Avatar
05.03.2016, 08:56 AM
Hi guys, it seems there isn't any change in the firmware, as it is still v1.72 released 11/10/2015, see below... so not sure why that was listed in the Link update.
I ran my XLX ESC a bit in a 10 kg 4WD Maverick Vader buggy, geared for 63 mph on-road on 2x5Ah 6s 65C Turnigy Graphenes with a 1195 kv TP Power TP5670 6-pole motor. Test-drive ended early because of motor issue, so I don't have a whole lot of input yet.
Torque control and punch control were disabled, start power set to low and Current limiting set to insensitive (220A). It did reach a little over 200A draw, but somehow it feels as if the power kicks in a bit delayed, like turbo lag. Best graph of throttle response I got is shown below, but I was modulating a bit throttle too much to draw any conclusions on this I think.
Will change gearing now for 66 mph off-road on stock tires, 8S and with an 1165 kv Leopard 5698, while the TP's shaft is curing. Should be nice weather coming days, so might be able to run it before the weekend.
[youtube]xbJjhoWSnwo[/youtube]
