KMN
KMN's Avatar
12.27.2016, 05:08 PM
Could you get a picture of what's going on?
If it's too long, can you grind down the pinion, or get a shorter dogbone?
I ended up with Mike's chassis, and if I remember correctly, 115mm rear dogbone, and 125mm front. I have the 35mm chassis extension on there and a Kyosho MP9 center diff, so those numbers will be different. I probably tried several different length bones before I finally found some that fit.
