Pdelcast
Pdelcast's Avatar
02.17.2017, 01:25 PM
Originally Posted by maxxximatoze View Post
So the iron losses for 16V should be around 54W, am I right ? I have a Hpi Alphastar 2350KV (If I'm remenber well, is a 1517 1Y with N28UH magnets and 0.35 lamination for cost killing which is, in fact, 2480KV@no load) that is burning 70W in iron losses at 16V, how many degrees difference between the two ?
It is controlled by a mamba max pro with 1.52 firmware, so the sensored mode attract me a lot ! Thx !
We are using a .2mm lamination, special High Frequency grade, Japanese steel. So the iron losses are quite low.
I think you should see about 1/2 the iron losses with our motor, vs a motor with standard .35mm laminations. In our motor, the iron losses are the minority losses -- more important is the copper losses. At 5 milliohms, the iron losses are about 50 watts at 100A.
Thanks!
Patrick del Castillo
President, Principle Engineer
