SpeedAssault
SpeedAssault's Avatar
03.15.2017, 03:39 PM
Oil
7k front
10k Center
5k Rear
Thank You RuuDxD
Even Castle did not know Power of 2200
Based on 120Amps:
2.84 ftlbs of Torque
Axle Torque 3.81
2.8 to 3.5HP
6S 25volts
Tire 4.8
Spur/Pinio Ratio 2.41:1
46Spur 19P
Theoretical Speed 78MPH
Calculated Motor Power 3024 watts (4.1HP)
At Under 11.5 lbs this would explain why the car from dead stop it Jumps straight up in the Air when Pull full throttle.
Trimmed down power, ran good.
car sat for couple yrs
Problem Now, throttle Stutters in begining, , give it a push and drives fine above 8mph. ??
