Pdelcast
Pdelcast's Avatar
12.12.2017, 03:57 PM
Originally Posted by maxxximatoze View Post
OK, it's certainly perfectly fine. Do you if high grade ceramic bearing can reduce I0 in a measurable manner, or it's useless ? (and make it run noise free, the orignal bearings tend to make some noise at different rpm)
Ps: what is the toshiba mosfet ref used in the mamba monster X, if it's not top secret, TPHR6503PL ? just to know... And I promise, I stop bother you with all my questions ;)
Ceramic bearings can make it both quieter and reduce IO -- but be careful, they damage easy. And the front bearing is especially easy to damage.
I can't comment on what MOSFETs we use. But you can probably read the numbers off the top of the chips if you are interested. :)
Patrick del Castillo
President, Principle Engineer
