04.13.2006, 04:02 PM
Your pharmacies don't have it?? That's weird!
Maybe you can check paint shops. It has a use in removing paint from wood, sometimes.
It's also used to bake some special kind of buns. So I guess bakeries use it too, but this is pretty far fetched. It's a common chemical, really. Should be easy to get.
You should get it, one way or the other. I hope a local can point you in the right direction.
