04.15.2006, 09:08 PM
i'm trying to install the outdrive cups from the g2r kit, do i line them up so the set screws go into the hole on the outdrive shaft, or do i put the cups on loose and fit the dogbones and then tighten the set screws wherever they end up as long as the dogbones fit good? how much play should there be between the cups and dogbones?
