04.16.2006, 05:44 PM
ok, i went over the fuel tubes, checked the exhaust for clogs, checked every motor bolt for tightness/leaks, changed glowplugs to a new one, checked carb for previous setting i made on it, yada yada yada.......
the fuel tank is the same type (stock t-maxx)
started it up and within 2 quick high speed passes it bogged WAY DOWN, idle slowed WAY DOWN, then cut off, i immediately checked temp....... 345f......
all this within less then 2 minutes of start up.....
im about this close to calling it quits with NITRO already !!!!!!
