cspurlock
04.16.2006, 09:03 PM
Originally Posted by MetalMan
If you can find a sensored system comparable in power to a sensorless system, then go for it! The reason why most of us here run sensorless is because there aren't any sensored setups comparable in power to the sensorless setups we run. If such a sensored system came out, I think many of us would at the least be very interested in it!
The Aveox is powerful like what we are using the only problem is that their software is not as good as what we are doing. I also doubt that their controller is going to hang in there with the heat.
If you really want to use Aveox, use a 1415, not 1409. If you want a new improved aveox with better efficiency and better magnets, and is sensorless, then buy a Neu Motor. That is exactly what it is. The guy who makes this helped design the Aveox motor. He just took that basic design and built on it with better magnets. The result is one hell of a motor! Here are the motors I own:
Neu
Aveox
Kontronic
Mega
Hacker
Lehner
Nemisis
Feigao
BK
The Neu is hands down the best(IMO).
