cspurlock
04.18.2006, 04:22 PM
Originally Posted by GriffinRU
With Kv=4400 forget about buggy conversion, unless you have 8 or less teeth pinion for 46t spur... or 66-72t spur with pinions you have :)
It is the motor which kills HV performance, wire HV-Novak ESC with good sensored motor (aveox...) and you will see BIG difference.
Artur
The kv on that motor isn't actually 4400. I know one of the R&D guys at novak and he told me that the way they test them is different then how the rest of the motors are tested.
I do agree with you that if you put a sensored Aveox on it, the performance would be much better. Why bother though.
