GriffinRU
04.18.2006, 08:24 PM
Originally Posted by DMCfirestar500
GriffinRU, are the aveox motors sensor wires the same as novak's? I mean can I just plug an aveox motor into a novak esc?
You need to make some modifications to match HV interface.
Here what HV expects:
Pin #1- Black wire-ground potential
Pin #2- Orange wire-phase C
Pin #3- White wire-phase B
Pin #4- Green wire-phase A
Pin #5- Blue wire-temp control, 10 k Thermistor referenced to ground potential
Pin #6- Red wire-+ 5.0 volts =/- 10%
Aveox motor has only 5 wires, A/B/C/Power/GND. I do not remember, right now which one is which, but if you have manuals or motor itself it is not that complicated. Then substitute thermistor with pull-up resistor to set 2.7V reference.
Artur
